| Posted by hj on September 30, 2002 at 08:59:53: | |
| In response to Re: honeywell Braukmann D06 F parts | |
Check with plumbing supply stores. That is the one we use and the wholesalers have the parts for them. There are two different springs depending on the pressure range. : Do you know how I can get the part or whole of the the above water pressure reducing valve? My problem is the broken spring inside the valve. I could not buy the same thing at any store. Can I replace it wih any other brand? How much will it be?
| There are none. |
