| Posted by hj on September 29, 2002 at 20:42:27: | |
| In response to Re: Leaking Toilet Still! | |
You may have done that needlessly. If the small refill tube that goes into the overflow pipe is inserted too deeply into the pipe, it will cause that behaviour. If this is the cause, pull it out and secure it either above the overflow pipe, or just slightly into it. : I have a 10 year Briggs toilet that fills back up every 6 1/2 minutes when the water level in the tank goes down. I have: : Replaced the flapper : Still leaks into the bowl but nothing on the floor. : Any help is appreciated. : Thanks : Bob
| There are none. |
