| Posted by hj on September 17, 2002 at 23:10:48: | |
| In response to Re: Replacing main shut off valve | |
IF that was the only thing he could find, he must have been really nitpicking to find something to report on. If the handle was just loose, then a screw or nut should reattach it. If there is a functional problem with the valve then a plumber can turn off the water and replace it fairly easily. : I'm in the process of buying a condo, and during the home inspection, the inspector pulled the handle off of the main shut off valve, handed it to me, and said "This is not a good thing."
| There are none. |
