Re: dual well pumps
Posted by hj on August 28, 2002 at 01:05:46:
In response to Re: dual well pumps
You have to install each pump as if it were the only one in the well. If you are using plastic drop pipes on submersible pumps you have to make sure that the starting torque of the pumps does not cause them to braid themselves together.
: I am going to install two well pumps (separate systems) on the same well. these pumps may or may not run at the same time. My question is : do I need check valves on the suction of each pump, and if so, what type do you recommend?
Replies to this post
