| Posted by Wayne Stinson on August 19, 2002 at 11:06:51: | |
My Bradford White 40 Gal. indirect water heater has developed a leak at the junction of the heater loop attachment fitting. The leak is from a small diameter hole which is to be drilled into the side of the fitting and is ordinarily concealed by the insulation material. The contractor who installed the system three years ago advises the tank is out of the warrenty period and will have to be replaced because parts are not available. Is there a servicable seal inside the fitting? What is the purpoae of the hole? Any help will be appreciated. Wayne Stinson |
