| Posted by hj on August 08, 2002 at 00:02:43: | |
| In response to Re: SWEATING PIPE | |
Since pipe is usually screwed together, refering to it sweating usually means there is condensation on it. Sweating copper tubing is a soft solder process. Silver soldering is a brazing operation which also involves the missibility of the media into the joint, but at a much higher temperature. : WHATS THE DIFFERENCE BETWEEN SWEATING PIPE AND SOLDERING PIPE COPPER SILVER SOLDER.
