| Posted by Terry Love on August 01, 2002 at 23:33:58: | |
| In response to Re: jacuzzi pump pressure is low | |
![]() : I have a jacuzzi bathtub and the pressure coming out of the jets has diminished to about 1/2 the normal pressure over time. : I've tried everything short of disassembling the pump and checking out the impeller. All the piping seems to be clear when I stick a hose into them and turn the water on. : When the pump is working, if I block three of the six jets, the pressure still does not seem to get back up to the normal pressure. : So I expect that I have to unbolt the pump from the vibration mounting, unbolt the impeller housing, twist the two large pipe unions off, and separate the pump to impeller part of the motor. : Any comments? Phil,
| There are none. |
