thank you all!
Posted by AJ on May 18, 2002 at 23:28:29:
In response to thank you all!
A-yup Terry I am about to throw mine away also.UGH
Re: sewer pipe "suddenly fixed".....simple. I had a plumber come in and she cut off the 20' of 3" sitting on the ground between the belly drop and ground drop.
She then installed female threaded 3" and glued elbow (90). Adjusted the pipe, giving it proper pitch, elevating it 1/4 to the inch. my sewer pipe under mfd home is properly pitched persay. :)
Replies to this post
There are none.
