| Posted by hj on April 28, 2002 at 01:09:10: | |
| In response to Re: drain for tiled tub | |
Normally you use the same drain as a shower, but replace the slotted grate with a Roman Tub top. : Terry, I'm building a tiled tub that will be waterproofed with either a sheet or trowel-on membrane. I need to find either a clamping drain, similar to that used in a shower, or some other type of drain that will integrate with the membrane. Any ideas? Thanks
| There are none. |
