| Posted by Gary Swart on April 27, 2002 at 12:03:56: | |
| In response to Re: Furnace Odor | |
That is probably what you have. The furnace has a drain for condensation and there is likely some moisture it is not removing which is causing the oder. It sounds like a good idea to have your furnace serviced and cleaned. Have the drain checked to see if there is anything that could be done to improve it. Don't look for a massive leak, if you had that, you'd have a flood when the furnace was operating. |
| There are none. |
