Re: Replacing drain pipe under kitchen slab
Posted by Gary Swart on April 14, 2002 at 17:45:09:
In response to Re: Replacing drain pipe under kitchen slab
When you say the hole is dug to get to the pipe, do you mean the concrete is broken out and the 7 foot trench is excavated, or just the end of the pipe has been found? Are you going to do the concrete repair is is the plumber? The more of that you can do, the less it will cost. I don't think you'd want to pay a plumber his scale for doing common labor on the digging. The cost just to replace the pipe should be too bad
Replies to this post
There are none. |
