Re: drain in landry room backing up
Posted by ClogCleaner on April 13, 2002 at 23:30:15:
In response to Re: drain in landry room backing up
: Most likely the drainline between the washer and the main sewer line is clogged. It could be in the pee trap or elsewhere in the line. I'd get a snake, you can rent one at most any rental store, and run that through the line from the washer end. I agree..but you may need to hire a drain cleaner because you may have to go on the roof to unstop it if you dont have a clean-out for that particularfixture. We would charge you about $50.00 from my company here in Texas to unstop it.
Replies to this post
There are none. |
