| Posted by Gary Swart on April 13, 2002 at 16:45:07: | |
| In response to Re: Sewer Problems | |
Immediate problem: get the drain, poor as it may be, to drain. It has to be plugged, from what you describe at or near the connection to the sewer main. I strongly recommend a plumber with a power snake. Once the immediate problem is out of the way, then you can proceed with redoing the drains. If you just bought this house, I believe you should consult an attorney right now. Of course photograph and document everything. |
