| Posted by hj on March 28, 2002 at 23:58:44: | |
| In response to Re: kant-leak wax rings | |
In the first place they should be called, "Shouldn't Leak but Do", wax rings. It will act as a funnel, but if you install it on the flange the sleeve will position itself automatically. : Should the plastic flange on the bottom of a KANT-LEAK wax ring fit down into the smallest ID of the bowl flange and act like a "funnel" or should it be the same size as the tail pipe on the bowl flange and sit on the recessed hub of the bowl flange? If it doesn't fit down in the tail pipe what keeps it from leaking?
| There are none. |
