soldering a fitting next to another one
Posted by oscar on March 24, 2002 at 09:42:40:
Hi, I need to tie into a water copper line where there's a joint about 12" away will the heat from the torch affect or melt away the soldering from that joint? ideally I would prefer to tie in closer to the existing joint as it will give me more room to work how close to the joint can I solder the fitting ? thanks for your advise,
Replies to this post
