| Posted by Wayne Cooper on February 28, 2002 at 17:20:34: | |
| In response to Re: toilet flange broken | |
: I removed the toilet to replace the wax ring (to solve rocking problem). The toilet flange (pvc) was broken also. I bought a new PVC flange, but how do I get the old one off. It was not properly installed - instead of 4 bolts hooking it to the floor, there were 2 nails (no wonder it rocked!). I finally got the nails out but the cracked flange won't come off so I assume it is glued to the pipe. How do I get it off to put on the new one??? I considered sawing it off even with the floor but then I would have no pvc pipe above the floor to put the flange over - can I get a flange that would fit inside the pipe instead of over? : Help please as what was once the upstairs toilet is now a "pvc hole". Thanks
| There are none. |
