Questions about Toto Drake
Posted by Richard on December 14, 2001 at 11:29:06:
Hi Terry, I have a couple of questions about the Toto Drake you delivered to my house a couple of weeks ago. First, thank you for your very helpful installation advice. I got it installed without much problem and it is working well, except for one thing. I find that it doesn't flush completely unless you hold the flush lever down. If you just pull and release, the flapper falls back down immediately and closes while the tank is still half full. Is this supposed to be, or is the tank I got missing something? Also, these models are advertised to have a glazed trapway, to reduce friction of waste material as it passes through. Sticking my fingers up under the hole at the bottom of the bowl, I can feel that it is rought inside, not glazed. So are they all like that, or did I get one from a bad batch? Thanks again for your very informative web site. Richard in Kent
