Re: Frozen Copper Pipes Under Deck
Posted by Detroit Home Inspector on July 20, 2001 at 15:49:19:
In response to Re: Frozen Copper Pipes Under Deck
I live in MI too. The other guy that responded is right, unless air can get in the line it may not drain. Solution: Just add a valve to that line in the basement. After you shut off the water for the winter, open the valve to let air in, go outside and open that valve. All the water will drain out...guaranteed. www.MIproperty.com
Replies to this post
There are none. |
