Re: Refrig is pooling water to bottom of unit/inside unit
Posted by C. on July 02, 2001 at 02:25:53:
In response to Re: Refrig is pooling water to bottom of unit/inside unit
I had this exact same problem. I turned off everything including the water supply and it still continued. After almost a year of putting up with removing the ice from the bottom and damaging the area, I called a refrigeration technician and all it needed was freon.
: I have a Magic Chef Refrig. that is about 12 years old now. It has a separate area for freezer and for refrig items(top/bottom). It also has an automatic icemaker. The auto icemaker hasn't worked for a couple of years and I've left the aluminum handle in the off ice making position.
: For the last month (all of a sudden) I have this pool of water forming in the very bottom of the refrig. Basically underneath the crisper/veggie single drawer.
: Does this have anything to do with the icemaker? Basic question, how do I stop this pooling of water in the bottom of the refrig. It must be sponged up every 2-3 days now or it starts running out the front of the drawer.
: Thank you very much.
Replies to this post
There are none.
