| Posted by Berto on May 29, 2001 at 22:23:37: | |
I would like to install a sink in my laundry room and use the existing water supply and drain that is now used by the washer to supply and drain the new sink. So, the washer and sink would share supply and drain. This seems like a quick and easy solution as oppossed to running a new supply line and new drain. Will this work? If it will work, are there any special materials, design intricacies that I should be build into the system? Thanks. |
| There are none. |
