Re: Bathroom Subfloor Question
Posted by hj on May 11, 19100 at 00:49:05:
In response to Re: Bathroom Subfloor Question
19/32 is a little light even with durock on it. Unless you do not have the room, 3/4" plywood with the grain perpendicular to the joists would the better way.
: I've gutted my bathroom and am now replacing the subfloor because of some rot. I've cut out the old plywood flush with the walls and now I'm wondering how much edge support I need.
: I"m using 19/32" plywood and am putting Durock on top for a tile floor. I'm a bit worried deflection at the edges and I don't want a cracked floor.
: Where the edges of the plywood run parallel to the joists, I've packed out with 2x4s where needed for a nailing edge and support. What I'm wondering I need anything for the edges that are perpendicular to the joists. Everything is on 16' centers. I cut a couple of 14 1/2" 2x4s and started toe nailing betwwen the joists and realized what a pain its going to be so I thought I'd ask.
: Thanks.
Replies to this post
There are none.
