| Posted by Barry Larkin on May 10, 19100 at 17:38:06: | |
I just bought an old victorian house,it has a well system,I have no info on the well pump,it has a 1" outlet on the pressure tank and the gauge reads 40 psi. Currently there is 3/4" cpvc cold water feed that goes about 30 feet to a crawl space beneath the kitchen floor where it is In the old kitchen I will be keeping the sink and adding a washing machine, and feeding a sink and dishwasher in the new What is the proper way to feed this setup, to get proper pressure and volume? Should I run a 1" cold main to the old kitchen, then feed all the fixtures with 1/2", or will a 3/4" main sufice? Should I extend the 1" or 3/4" main up to the bathroom? Should I replace the 1/2" hot water main with 3/4" (there are 3/4" fitting on the water heater)? P.S. I will be installing and aeration/carbon filter for hydrogen sulfide removal after the pressure tank, if this would affect Any advice would be greatly appreciated. Thanks, Barry Larkin |
