| Posted by Julian Craddock on May 01, 19100 at 14:58:19: | |
I currently use my hot water tank to provide hot water for domestic purposes and to heat my home via a coil in a forced air furnace. In the future I would like to extend the system to heat the water for an outside hot tub. I would also like to add a central air unit. The current hot water tank is a low/mid efficiency unit and I would like to replace it with a more cost effective solution. I live in Ottawa Canada , I am on well water, and currently use oil although natural gas is available. I am currently aware of two options: 1.) Use a high efficiency storage type heater (polaris or similar), or 2.) A tankless heater such as an aquastar. I am interested in more information on the following: 1.) If I use a tankless heater do I also need to use a storeage tank. If so, do I loose the efficiency 2.) 140F and 180F are often provided as the target water temperature. In a hybrid solution, what is the 3.) If I use an efficient storage heater am I better off to go with a boiler? If I use a boiler can I also use it 4.) I currently vent the oil hot water heater with a side shot. It is noisy. Can I vent a tankless solution with 5.) The current solution uses a couple of check valves to stop the hot water cycling through the heater 6.) With regards to tankless solutions are there opinions on the most appropriate model (e.g, Aquastar, Thanks in advance, Julian. |
| There are none. |
