| Posted by Terry Love on August 13, 1998 at 14:34:23: | |
| In response to Re: Leak from upstairs bathroom to basement | |
The leak could be from many things. Leaking joints, drain lines, water supply pipes, If you think the p-trap is a problem, it would be a good place to start. Finding water leaks can be a challenge in that water will find the easiest way down. An exception would be the "wicking" that occurs around shower and tub walls if the porous material is too close to the shower pan. |
| There are none. |
