| Posted by Weogo Reed on January 18, 19100 at 00:04:43: | |
| In response to Re: removing galvanized pipe | |
Hi Brian, : Brian, They make a tool called a hack saw. It saws metal. cut about 6" from each end then unscrew the pipe. I hope you are a calm fellow as this could turn into your worst nightmare. Even us old timers fear working on the old galvanized. Have a good plumber on standby. Good luck with your project. Dale Peck LMP Dale has the right tool to start with. After you cut the pipe, you can thread male CPVC adapters into the elbows. Last, take a good look at the pipe you removed. Good health, Weogo |
| There are none. |
