Re: jacuzzi tub, some jets very weak
Posted by JOMZS on January 17, 19100 at 14:25:02:
In response to Re: jacuzzi tub, some jets very weak
: : I have a new house (< 5 onths old) and half of the jets in the jacuzzi tub are extremely weak.
: : The problem is on one side of the tub only, the other works fine. I'm not sure if I stopped the one side up
: : (with bath oils etc) or if there is some other problem. Has anyone else had a problem like this? What did you do?
: : I've considered filling the tib with extremely hot water (to try to melt the block) or to run drain cleaner
: : through it but am afraid to do the latter in case it might harm the tub even more. Any advice??
: Sounds like the air intake for one side is closed. Check to make sure both are open. The mixture of air and water gives the jets that "force" Terry
: If air intakes are open, check the actual jet face....may of Jaccuzi brand bathtubs have water jets that are flow adjustable...simply turn clockwise or counter-clockwise to adjust flow.
Replies to this post
There are none.
