Posted by Terry Love on January 16, 19100 at 21:35:56:
In Reply to: jacuzzi tub, some jets very weak posted by J Colvin on January 16, 19100 at 19:15:29:
: I have a new house (< 5 onths old) and half of the jets in the jacuzzi tub are extremely weak.
: The problem is on one side of the tub only, the other works fine. I'm not sure if I stopped the one side up
: (with bath oils etc) or if there is some other problem. Has anyone else had a problem like this? What did you do?
: I've considered filling the tib with extremely hot water (to try to melt the block) or to run drain cleaner
: through it but am afraid to do the latter in case it might harm the tub even more. Any advice??
Sounds like the air intake for one side is closed. Check to make sure both are open. The mixture of air and water gives the jets that "force" Terry
