| Posted by Dale's plumbing Service on January 03, 19100 at 07:49:53: | |
| In response to Re: Hot water pressure | |
: All of a sudden my hot water pressure at home got weak while my cold water pressure is fine. What do you suggest I look at in determining the problem? The water heater is approx. 8 yrs old. There are no rust spots or signs of excessive wear on the outside. I did not see any leaks and the valves are open fully. Thanks. Dino, I have found in the past that the nipple or male adapter on the hot outlet of the heater gets plugged. It also gets plugged on the cold. Hope this Helps. Dale Peck LMP |
| There are none. |
