Re: Put in Toilet
Posted by Dale's Plumbing Service on December 28, 1999 at 18:20:10:
In response to Re: Put in Toilet
: Hello,
: I want to put a toilet in downstairs. The problem I have is the downstairs is solid cement. The toilet will be placed 9 feet away from the drain coming from a toilet upstairs.
: Can I cut a hole in the floor about four feet deep to the drain from above in Y into it?
: Then pour cement back and put in the toilet?
Matt If your line is 4 ft in the groung you should be able to cut a 4x3 san tee in the vertical line. Install a 2in vent in the line going to the stool and bring the vent out the roof or into another vent the same size or bigger. Dale Peck LMP
Replies to this post
There are none.
