Re: installing a jacuzzi
Posted by hj on August 03, 1999 at 11:19:41:
In response to Re: installing a jacuzzi
We do not usually use sand, since that will vibrate and settle away from the bottom of the Jacuzzi. Either use an expanding foam, cement, mortar bed, or some other permanent material.
Vibration is not the problem as much as the weight of the water and users which must be supported by something other than the edges of the tub, if you do not want stress cracks to develop.
: Is there a phamplet or info sheet on how to install a jacuzzi. We ere jkust told that it should be cushioned by a bed of sand for the vibration. Is this correct?
Replies to this post
