Re: Wall-hung toilet
Posted by hj on August 01, 1999 at 20:48:35:
In response to Re: Wall-hung toilet
The carrier fitting required for a wallhung toilet is quite large and negates any height advantages. It also makes the wall much thicker.
: I'm finishing the upstairs of a 30 year old,
: one-and-a-half story house. It has 2X10 floor joists,
: but the drain lines for the toilets will be tough to
: fit in the available space and maintain the required
: drop. Is there any advantage to using a wall-hung
: toilet? I assume that it has a higher outlet from
: the trap than a floor-mounted model, so this would give
: more vertical drop for the drain pipe. Any thoughts?
: Thanks.
: - Matt
Replies to this post
