| Posted by Terry Love on June 08, 1999 at 21:18:00: | |
| In response to Re: Replacing drain pipe in concrete slab | |
![]() I have not tried the masonry blade for concrete cutting yet. I have used diamond blade wet saws, chipping hammers and sledgehammers. Once the pipe is exposed, you can cut it and replace the bad section of pipe with ABS or PVC using the proper coupling. You can buy the ABS to CI coupling. Sometimes you can remove a pipe from a hub fitting and use a rubber tyseal bushing in place of the old lead and oakum joint. We do these all the time. Terry |
| There are none. |
