Re: Gas appliance pilot lights
Posted by Lou on May 07, 1999 at 00:06:02:
In response to Re: Gas appliance pilot lights
Have another look at your appliances, check out the main burner and general area. Then stand back and turn up thermostats until main burner ignites, you may need a helper in the case of the furnace. Look for where the fire starts from, pilot will be close by. Turn down thermostat, or control knob, if pilot remains on you don't have electronic ignition, and will have to re-light the pilot. A test run now before you have air in the lines will save you time later.....Lou
Replies to this post
There are none. |
