Re: Slow drains, blooping toilets, and bad smells
Posted by Lou on April 19, 1999 at 13:39:31:
In response to Re: Slow drains, blooping toilets, and bad smells
: This is a 3 part question, answers to any and all are gratefully welcomed. A little background: I am in a double-wide mobile home on a septic tank. : 1. Slow drains. What is the best product/home formula/procedure to use on slow drains in the shower and bathroom sink? Remove the trap if possible and mechanically clean the drain, you will remove all obstructions this way. Also check drains for proper grade. : 2. Blooping toilets: When the bathtub is draining, both toilets will "bloop" for a few moments and once the tub gets down to a lower level of water the blooping will stop. Why? and how do I fix it? Check your venting, it is either incorrect or plugged. Also check your septic tank. : 3. When the washing machine or dish washer will drain, the kitchen sink will gurgle and heave out a nauseating smell, is this related to my 2nd question? What do I do? : Thanks in advance for any replies. -Eric
Replies to this post
There are none. |
