| Posted by Dale's Plumbing Service on April 17, 1999 at 10:07:48: | |
| In response to Re: tub enclosure | |
: Can you give me any tips on installing a tub enclosure mario, well first make sure the sheet rock is in good shape, replace all bad sheet rock with blue sheet rock, i use wonder board a concrete type of board used around tubs showers,etc. tape and spackle all seams. make sure every thing is clean and dry. use only the glue suggested by the manufacture.and use a 4' level.use a hole saw to cut out you holes for the faucet.good luck on your project.
| There are none. |
