Re: removing exiting bathtub fixture with shower
Posted by Dale's Plumbing Service on April 10, 1999 at 01:41:19:
In response to Re: removing exiting bathtub fixture with shower
: what is best way to remove entire fixture without damaging the tile, etc.? has michigan brass broken seat and broken threads behind seat .ever happen to you?
If you have 4-1/4" tile take a utility knife and cut along grout line and into sheet rock. cut a square big enough to get old faucet out and new one in. use f26 and c-clamps to glue 1x2 accross the opening (top & bottom) and glue square back in place, and regrout.if you are not sure if you can do this then hire it done unless you have spare tiles to match. good luck. Dale
Replies to this post
There are none.
