| Posted by James on February 04, 1999 at 21:00:54: | |
Hi! I need your help? If a lead pan is installed and you install the wonderboard on the walls how high do you have to put the screws from the floor and if you put the screws through the lead pan will the lead self seal the screws?. The reason i'm asking this question is a plumber installed a lead pan and i did the tile work . 5 months later the lead pan was leaking and the plumbers came back and they said that i put screws through the lead pan and that's the reason it was leaking. Please can you help me with this question asap?. |
