| Posted by JK on May 04, 2002 at 02:40:04: | |
| In response to Re: Sulfer smell in shower only | |
Same problem here. Yes it is sulfer and Iron. If you are on a septic and well like I am. The only thing I know of that will work effectively and long term is water treatment and conditioner and good filtration system and having your septic tank drained at least once a year. You want to make sure not to get a copy cat type water treatment and conditioner and filtration system but get good ones from reputable dealers. You can buy water test kits this is how I reccomend you use the test kit do your test before running water out of a faucett not filtered then run a shower for a while and then do the test again especially the sulfer iron and bacteria. keep track of the recults before running the shower and then after running the shower and compare the 2. use the hot side of the fauctet for the sulfer test. Sulfer is a problem that can come and go or be constant. sulfer iron will show up on the hot water side higher than on the cold side. If you need to know some of the companies that sell the good brands of filtration and conditioner systems you can email me. If on a well you may want to consider disinfecting your well of you can to do this use 1 gallon of bleach for every 50 feet deep then run the faucets inside for about a minute to 3 minutes one faucet at a time then take a garden hose and run some of the water down on the sides of the well to clean off the sides then run the rest of the water out into the woods away from your well and septic where it won't damage rivers or nearby neighbors water. Run the water until you no longer smell the bleach. The good filtration and conditioning systems are not cheap in the beginning but require less maintance and work significantly better than cheap ones and are cheaper to maintan than ones you have to buy filters for every month or every 3 months. water problems can pose a real heath risk and some contaminants can cause cancer, problems thinking, neurological problems, asthma, gardia (also known as bever fever), lukemia, short attention spans, growth and development problems, pregnancy problems including premature births etc. If the person that looked at your pipes and saw a rust type look on the inside of them than there is a high possibility it is sulfer. If you want a more thourghal test than the standard ones sold in stores you can sometimes get them through phsiology or biology professors on university campuses. when you find problems with water when testing it is a good idea to do more throughal testing on these you'll need to use a microschope and plastic strips and dies. If there is any chance of contamination above acceptabilty you will want to aviod taking samples to labratories or epa as they can force you to move or spend thousands to fix it. and labratories that serve people are required by law to call epa if a bactera contamination problem shows up on the test. Some Sulfer problems can be caused by bateria and thus present health problems. If you have a friend in your area like a pharmacist or someone taking biology at the university that has access to a microscope you might consider asking them if you can use their microscope or if they can bring it to their home or office and do the testing with you. For small particals you really need a powerfull microscope to see them and they can be expensive. A friend who is a pharmacist that can do the test with you would be real helpful as many of them know biology and chemistry real well and know what to look for. sometimes you can end up with a contaminant that don't show up and have to use an alterantive method or test again to find the contaminant and many pharmacist know what alternatives to use and will know what it is suppose to look like with the alternative method used to find the contaminant. If you have a septic you may consider checking for leaks at the beginning to the middle of the system because when the clog and don't go completly through the leach field the stuff don't disolve enough and can have an area where all the liquid is draining out of one area and where that is a case and it is on sand you can end up with a real problem with the water table and where the well water comes from... Plants that have roots that soke up nitrates planted out in a leach field can help a little also. but that will only help a little bit in the summer time and won't work for winter. I'm one who likes to totally solve a problem as best as possible not half baindaid a problem that won't work or work as well which is why I listed all these methods and why the post is so long. Sorry if it inconviences anyone..
: Thanks,
| There are none. |
