| Posted by Jack on April 10, 2002 at 15:17:50: | |
| In response to Re: Specs for Irragation system pump | |
: Yeah, I know you could design the system, then look at the gpm of each sprinler head in each zone, etc, etc, However, I am probably going to install a pump just supplying some lines to run big standalone sprinklers this year, then see about sinking more money in for the inground system. I suspect for a given size property, the pump requirements are fairly predictable. So I wanted to get something that looks like it would take care of the inground irragation system. : : You should design the lawn irrigation system first and then provide a pump that will supply its needs. While designing it, you should also consider the potential pumps that are available within your budget. It is sort of a catch 22, since one will affect the other. : : : Anyone have some suggestions for a pump for an lawn irragation system. I would like to pump out of my pond. I don't need much suction lift. I have approximately 3600 sq ft of lawn. I would like to know typical gpm and pressure requirements for a lawn sprinkler system. : : : Thanks in aadvance. : : : -Curt
| There are none. |
