| Posted by hj on November 19, 1998 at 09:31:02: | |
| In response to Re: Soil drain pipe | |
The green pipe is a lightweight PVC pipe. It is subject to distortion and crushing if buried too deeply. It is also undersize on the outside diameter so you need adapters at both ends to connect to standard size piping. : What is the difference between schedule 40 PVC pipe and SDR-35 (green?) pipe. I need to replace the drain pipe from my house to my cesspool. I've been told to use schedule 40 PVC by some and SDR-35 by other plumbers. Which one should I use? Does it matter?
| There are none. |
