Re: Oil Furnace stopped with full tank.....HELP!!!!!!!
Posted by Bud..Suncoast Plumbing Inc. on November 16, 1998 at 22:23:37:
In response to Re: Oil Furnace stopped with full tank.....HELP!!!!!!!
Terry:--I am assuming that this is a gun fired oil burner type furnace....................
Was the furnace running at the time of delivery, or had you run out of fuel? Is this the first time you have had the furnace fired up this year?
IF it ran out of fuel, you may have to bleed the air from the pump.
IF it was running when the fuel was delivered but stopped after, I'd be calling the Oil Man and tell him about this (a little water in an oil line can be a headache)
If this is the first time this year that your firing this furnace up..Don't forget that there is a safety switch that may have to be turned on before it will light. Lots of luck...Bud
Replies to this post
There are none.
