| Posted by Philip J. Klement on June 28, 2001 at 11:06:30: | |
| In response to Re: dirty jaccuzzi jets | |
: : Our jaccuzzi tub is great but the jets are letting out some black deposits (algae? water deposits?) in the water. What can we use to clean the jets and to prevent this from reoccurring? Thank you. : Try dishwashing detergent, that's what I'm doing right now. Found something on the Sanijet site that said regular jacuzzi tubs are cleaned by running dishwashing detergent through the jets with warm/hot water. Then drain and refill to rinse. Called for two tablespoons but since I read this after I started, I think I dumped in a cup of it. Hope it does the trick for both of us.
| There are none. |
