| Posted by Rod R. Schurman, P.E. on April 21, 19101 at 09:06:41: | |
| In response to Re: copper to plastic | |
You have two choices: "sweat" (weld) an adaptor fitting onto the copper line or, since it is a waste line, use a clamp adaptor (basically a short rubber hose with hose clamps). If the waste line never runs full, you can used the clamp no problem. If there is pressure in the line, you should consider the first method.
| There are none. |
