| Posted by hj on March 14, 19101 at 23:44:37: | |
| In response to Re: bathtub drain | |
Pull it up and hold the big circle with a pair of pliers. Then use a second pliers to unscrew the small knob on top of it. Then use a screwdriver to remove the post that you will find under the knob. : I have a slow draining bathtub that probably need the stopper taken out and cleaned of hair. However, I cannot get the stopper out. It is a brass with a small knob on the top to hold on to and turn to open and close. The brass cover over the overflow says "Watco". Can you help me!?! Thank you.
| There are none. |
