| Posted by Bud..Suncoast Plumbing Inc. on February 13, 19101 at 19:48:49: | |
| In response to Re: Complete replumbing of old house, copper in, or under slab. | |
Carl:It is possible to pull new replacement HDPE lines through the failed copper lines with great ease and success. The volume of water delivered to each fixture will be somewhat less that that delivered by the original piping scheme. In todays reduced flow mandate, the difference will not be noticeable. Minimal upset to the premises and substantial savings can be had by those who elect to use the failed piping as a means to thread new lines in. Bud.. I have a 2300 sft house on slab. The plumbing, I discovered when water started coming from the wall, is either under or in the slab. Replumbing into the attic is the only viable solution that I see. Would cpvc be the material to use? Even though I have installed toilets, sinks, drain systems in new construction, I'm not certain of the methods used to replumb. I'm so old that my experience is with the old iron pipe. : I'll probably have to contract the job out. : Carl
| There are none. |
