Re: water pressure
Posted by Terry Love on November 07, 19100 at 10:12:56:
In response to Re: water pressure
: Would remodeling a shower faucet from a two handle control to a one handle control reduce the water pressure? Can I adjust water pressure on a gas water heater or must I call the plumber? Mine never show up anyway....
There should be pressure either way. Some single controls allow for more flow than others. The new shower heads are low-flow anyway. I have seen old style heads in bathrooms that allow so much water through, that they can drain a 50 gallon water heater in minutes.
The water heater would not be the expected place to look for restricted pressure in a home unless you are thinking of a "on demand" heater. Most water heaters have 3/4" in and 3/4" out. Plenty for several fixtures to run at the same time.
The water heater can be adjusted for temperature though. An overly hot water setting can be dangerous though. Terry
Replies to this post
There are none.
