| Posted by hj on October 03, 19100 at 09:42:09: | |
| In response to Re: Water Flow Stops When Another Faucet is Shut Off | |
Watch the faucet handle when it occurs to see if it is moving. If you have one of the faucets that close with the water flow, the sudden pressure change can shut them down if the stem packings are fairly loose. : We have two (2) sinks in an upstairs bathroom. When the water is running in both sinks, often when 1 faucet is turned off the water flow in the other sink either drops significantly or shuts off. It is usually accompanied by a clunking sound. In a couple of instances, when 1 sink and the shower were simultaneously being used, and the shower was turned off, the sink water pressure again dropped or shut off. : What could be causing this? Is there a fix?
| There are none. |
