| Posted by Nick on September 20, 19100 at 11:38:57: | |
| In response to Re: Leaky sillcock | |
: : I have a home that is 1 1/2 years old with a outdoor sillcock in the garage. There is an anti-siphon device on it that leaks especially after the hose is turned off and the water is released from the hose. : : The handle is a large dark grey handle and there is a plastic dark grey cap on top that reads Mansfield, Perryville, Ohio anti-siphon. : : Does the entire sillcock need to be replaced or can it be repaired? : Not entirely correct. Some anti-siphon Freezeless Hydrants will drain when the water is turned off, Prier Model C-434 or the Woodford 25 are 2 types that will drain after the water is turned off. The Mansfield 578 series is not suppost to leak after the water is turned off, similar design to the Prier C-144 or the Woodford 17. As Dean correctly points out, the vacuum breaker assembly on the Mansfield Hydrant can be replaced. Contact your plumber or plumbing wholesaler for the part. Good luck. Nick |
