: Need help on making a decision. Looking to buy a hot tub. What are the advantages of buying one with air jet blowers? Or one that only has the regular water jets? About the only difference is that the air jet is more powerful than a water jet. On the one I own, when you turn the air on, the water comes out under more pressure, it also bubbles the water. This creates a problem only if your bathing suit has a lot of leftover soap in it, because the water will foam up. They sell some foam down to solve the problem.
