| Posted by Dick on July 20, 19100 at 23:15:15: | |
| In response to Re: water piping | |
: i live in a area that gets to -50F. i want to install freeze proof piping, which type should i use and will it be ok for hot water? Depends... what do you mean by freeze proof?? If by freeze proof you mean can withstand an ocassional total freeze up without damage. Then you better talk to somebody about a secound mortgage. most conventional hardware store pipe fittings and valves will not stand up to this. You'll need heavy wall stainless tubing and fittings, high pressure valves etc, and there is no way to freeze proof the connection to conventional plumbing fixtures, so you'll end up with a real funky looking kitchen sink and shower!! I saw some pictures of what looked like this type of plumbing in amilitary outpost of some kind that was ocupied intermitantly. It was just in the background so i couldn't see much detail.
| There are none. |
